4 members (Jeff Ogden, ShopRag, ndkid275, 1 invisible), 132 guests, and 1 robot.
Topics128,209
Posts1,057,464
Members48,471
Is it hard to install a T5 trans out of a s10
Will it mate to my bell housing or what do I use , this is going in my 3/4 ton
Ideas ?
Shouldn't be hard at all, although I am not sure about the '46 bellhousing match up. Do you have the 235 bellhousing? Check the tech pages here and other sites. Plenty of info on the web.
Drew
I had to get a transmission adapter to mount my T-5 in my 46 1/2 ton the t=5 wont bolt up to a 46 bellhousing without it, I got mine from transmissionadapters.com the name of the company is called BENDTSENS TRANS ADAPTORS.... call them and they can set u up with everything you need to put the t-5 in. they even set me up with the right clutch disc
