1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#9922 06/09/2004 6:41 PM
I purchased a new drag link (not just the repair parts) for my 49. It's going to take some force to get the ball ends into the link. They go about halfway and then hang up. Is this normal?
#9923 06/09/2004 8:19 PM
It's a pretty tight fit. I just put my rebuilt old one back on last weekend. Make sure that you have all the right parts in the right order as shown in shop manual. I had one of the stemmed plugs that was longer than it should be and it would not let the spring compress to go over the ball. Once I got the right length plug in place it snapped on pretty eassily
#9924 06/10/2004 11:30 AM
Sometimes those kits have two of the longer length instead of one long and one short. The longer one will not fit in place of the shorter one.
What seal are you using, metal or neoprene ?
1951 1 Ton Completed
#9925 06/13/2004 2:13 PM
Have not had the time to research this, but can someone tell me if the '53-'54 drag link with the integral studs can be used on the earlier AD trucks? That would seem to be a major improvement in handling and safety. :confused:
#9926 06/13/2004 4:27 PM
Someone posted here in the last month or so stating that it could be done.
Jason
