| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 11 New Guy | | New Guy Joined: Dec 2013 Posts: 11 | Is it hard to install a T5 trans out of a s10 Will it mate to my bell housing or what do I use , this is going in my 3/4 ton Ideas ? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Shouldn't be hard at all, although I am not sure about the '46 bellhousing match up. Do you have the 235 bellhousing? Check the tech pages here and other sites. Plenty of info on the web.
Drew
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I had to get a transmission adapter to mount my T-5 in my 46 1/2 ton the t=5 wont bolt up to a 46 bellhousing without it, I got mine from transmissionadapters.com the name of the company is called BENDTSENS TRANS ADAPTORS.... call them and they can set u up with everything you need to put the t-5 in. they even set me up with the right clutch disc | | |
