0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I purchased a new drag link (not just the repair parts) for my 49. It's going to take some force to get the ball ends into the link. They go about halfway and then hang up. Is this normal? | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | It's a pretty tight fit. I just put my rebuilt old one back on last weekend. Make sure that you have all the right parts in the right order as shown in shop manual. I had one of the stemmed plugs that was longer than it should be and it would not let the spring compress to go over the ball. Once I got the right length plug in place it snapped on pretty eassily | | |
#9924 06/10/2004 11:30 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Sometimes those kits have two of the longer length instead of one long and one short. The longer one will not fit in place of the shorter one.
What seal are you using, metal or neoprene ? | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Have not had the time to research this, but can someone tell me if the '53-'54 drag link with the integral studs can be used on the earlier AD trucks? That would seem to be a major improvement in handling and safety. :confused: | | | | | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Someone posted here in the last month or so stating that it could be done.
Jason
