1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#991781 12/10/2013 5:38 PM
What would be the length, depth to the floor, and width of the inside of a 1946 Chevy box? On the outside of the box what would be the height from where the box bends upward to the bottom edge?
When I have some time I'll measure mine. Do you know about http://www.mar-k.com/Catalog/PDF/Instructions/37-53_Angle_Strips.pdf
GWWirth #991944 12/11/2013 2:05 PM
Thanks,I've been on there but didn't find anything. I did find out what the depth of the floor and the width are. I would still like to know what the length and the height is from the bottom edge to the bend of the top rail.
Here we go - 18.75 outside height to angle bend. Angle bend to top 2.25. Bend 30 degrees. 16.375 from top of wood bed to top at roll. Roll 1.5 dia. Outside length 79 11/16in. Front inside width 48 3/8, tailgate inside width 48 5/8 (no comments from you machinist types, what's a 1/4inch among friends) 78 inches long inside front bed panel to outside steel bed rear cross member. Drawings are so much better.
Thank you sir.
