7 members (Otto Skorzeny, Hotrod Lincoln, Slick Willy, 1955 1 Series, GrandpasJimmy, BarryP, 1 invisible), 95 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
#991994 12/11/2013 7:52 PM
Are there any ring and pinion gears that will work to get me away from 456
3B Offline
Hy Broke tim, welcome, there are 4.10 or 4.11 ratio gears available from a donor truck from up into the early seventies, those are the best gear ratio (for top speed) that are available. If you search around on here you will find many posts on the subject, hope that helps.
Eaton HO72= Chevy 67-72 3/4 ton trucks with a 4.10. It will bolt right in. Factory option. Takes patience but they are out there. The matched pinion bearing set, if needed, are pricey but can be found.
1946 GMC Project
"Back-in-the-day Restore"
I;m in the same boat with a 50 GMC 3/4t. Worst still I'm in the UK.
I'm sure I have read on here new sets are available?
Anyone know if this is still so? If so where from?
Cheers
