3 members (78buckshot, klhansen, 1 invisible),
152
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99200 02/11/2007 4:09 PM | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | Hello, I have a 1942 chevrolet truck, and recently i had the voltage regulator repaired( it's a special one) from leece neville company, and the truck was chargin fine i bought a new battery the same kind as previous from napa 6 volt, and now the wire or cable its silver going from the ignition switch to the top ignition post on the voltage regulator is scaulding hot. it even melted a plastic zip tie that was holding a bunch of other wires together. does anyone have any idea why? | | |
#99201 02/11/2007 5:27 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if you have any wire that hot you have a large current draw,or very bad connections,don,t know much about the chg system on your truck but retrace what you have done as something willnot live long ...doc | | |
#99202 02/11/2007 6:23 PM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 |
#99203 02/11/2007 8:13 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike,
As doc41 pointed out, excess current flowing through the wire will heat it. You mentioned that this 'wire' is silver...a strange color for a wire. Is it an copper, insulated wire.
Wires are rated for ampacity. Big ones will carry more current than small ones. If a wire is undersized for its application, it will heat up, and can actually melt the insulation off.
If this wire feeds the ignition switch, I wonder if it now is toast. It has a maximum rating too.
Was the key left on by accident...I think it has a different OFF position than most folks would be used to. If the flow of power was from that terminal on the regulator, through the wire and ignition switch, I wonder where it was headed?
Unless it was a 'short', then power was flowing because a switch was closed and a device was using the power.
If a key is left on, the ignition system will use power. This can cook a coil and burn out points. Will the engine still start. Good luck and keep digging.
Stuart | | |
#99204 02/12/2007 1:36 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If the ONLY thing you changed was the battery between working properly and not, then either the battery is in backwards or the wire was overheating before the battery change, without your knowledge. | | |
#99205 02/12/2007 2:45 AM | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | well, the engine still runs and the thing still charges. but, we have other things that run off the ignition switch. this stuff was all wired previously and worked great, the unit also has a 6 volt to 12 volt booster(somewhere) to run old motorola radios, im going to try running the vehicle without the radios on, as this may be the problem. as far as the key being left on accidentally, i doubt it, and the battery is in correctly. i will do some more troubleshooting and get back. | | |
#99206 02/12/2007 5:22 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if there's too much stuff runnin off that wire, it may need to be a heavier gauge wire, heavier than one might use on similar 12V applications
Bill | | |
#99207 02/13/2007 11:22 PM | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | I tried it again today, the results were so far so good. the engine ran for a good 10-12 minutes(i dont like the -degree windchill here in buffalo) i have a laser heat sensor and it didnt go any higher than 70 degrees. that is about the temperature of the garage the truck was stored in. | | |
#99208 02/14/2007 12:26 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike,
What did you turn off..electrically speaking. Why is that wire not cooking anymore. You need to see cause and effect to help troubleshoot this problem.
Stuart | | |
#99209 02/14/2007 1:59 AM | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | from this point, im not exactly sure what i turned off. i have only a few radios that run off the ignition, and the gauges(which obviously are not the issue). i have not changed any wiring before i started working on the faulty charging system, everything is the same. my radios run off a 6 to 12 volt booster, but its only a 3 amp draw. my attention mainly focuses on a old motorola radio, which may be going on the fritz. for todays trial, that was turned off. thanks for your help. | | |
