1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have a question for you guys that know the 1954 3100 Chevy truck frames. I met a guy through a metal guy that is building a 1954 3100 truck. The crossmember that came with the truck was really modified,so he bought a 1954 crossmember from a supplier.The crossmember in the picture is supposed to be the correct crossmember for it. As you can see in the picture,there is a bracket riveted to the frame rails on each side(factory rivets). crossmember picture Is this factory or did someone do this modification ? The truck had a 1947-1953 bellhousing in it,he now has a 54 bellhousing and crossmember for it. Thanks,Tim Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Looks like a Hydra-Matic truck. The stock crossmember unbolts. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I asked what transmission was in the truck when he bought it,he said 4 speed manual shift.The brackets have to be removed to use the replacement crossmember he has.Was there two different crossmembers for the 1954-1955.1 truck ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is the 1954 engine rear support cross-member. As Cletis posted, the engine rear support in a 54/55 Hydra-Matic was not riveted, it was bolted on; and, the 1/2 ton H-M had a rear-transmission bolted-on cross-member (the manual transmission 1/2 trucks had no rear-transmission cross member). | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | So do you have any clues on this setup ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are the brackets inside the frame rail welded in or riveted in or bolted in? I cannot see inside the frame rail.
If I remember, I'll take a photo of the Hydra-Matic cross-member attachment point tomorrow morning.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | It's riveted in like I stated above.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If they are riveted, there is no need to post photos of the H-M setup.
So, in answer to your question, "Was there two different cross-members for the 1954-1955.1 truck ?", there was only one 1954/54st 31xx rear engine cross-member for manual transmission trucks.
Most likely, whatever is attached at the cross-member mounting point will have to be removed. Do the rivet holes in the frame match the holes on the replacement cross-member?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yes,we know the brackets have to be removed to use the new crossmember he has.We just wanted to know if it was factory or if someone attached them to the frame. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | OK,there are two different crossmembers.One for Hydra-Matic truck and one for manual transmission truck. Pictures are worth a thousand words.He said the rivet holes do line up with the 54 crossmember he purchased.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
