| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | What would be the length, depth to the floor, and width of the inside of a 1946 Chevy box? On the outside of the box what would be the height from where the box bends upward to the bottom edge? Thanks | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Thanks,I've been on there but didn't find anything. I did find out what the depth of the floor and the width are. I would still like to know what the length and the height is from the bottom edge to the bend of the top rail.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Here we go - 18.75 outside height to angle bend. Angle bend to top 2.25. Bend 30 degrees. 16.375 from top of wood bed to top at roll. Roll 1.5 dia. Outside length 79 11/16in. Front inside width 48 3/8, tailgate inside width 48 5/8 (no comments from you machinist types, what's a 1/4inch among friends) 78 inches long inside front bed panel to outside steel bed rear cross member. Drawings are so much better. | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | | | |
