1 members (ndkid275),
50
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | Does anybody know why I couldn't run a throttle body injection upside down?
I'm dealing with a COE so I'm stuck with an updraft carb situation. I really want to keep it a Six. I'm going to rebuild the motor , it's a 1955 235 inline and I'd like to get some more beans out of it. Nothing radical, still a truck motor, but a little more compression, little more cam, a little head work, split manifold and why not an upside down TBI or two?
Let me know your thoughts, if you know why it won't work, you could save me some aggravation.
Thanks, Greg
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Why not rig a 90 degree elbow to the stock intake, and mount the TBI vertical instead of upside down? Of course, you'll need the full complement of sensors and an ECM to match the throttle body, wire harness, etc. but that can all be scavenged from a suitable donor vehicle. Since you'll be making an adapter any way you go, try a 2-injector TBI from a GM 3.8L V6. It should flow plenty of air volume without having to deal with the hassle of synchronizing two single-barrel TBI units. Jerry
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | I was reading about how the injectors are designed to handle vaporized fuel to avoid vapor lock. Something about a channel that allows the heavier liquid fuel to sink, forcing the vapor up a channel and back into the return line. Seems as long as it doesn't get heat soaked, this wouldn't be a problem. I'm looking for TBI parts myself right now. Trying to source from craigslist, paper and friends. Looking tommorrow at junkyards. Good luck with yours. Jim | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | interesting... I wonder if
"Something about a channel that allows the heavier liquid fuel to sink"
works off of gravity.
If so, that might mean upside down won't work
Thanks, Greg
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Yeh, that's why I mentioned it . I don't have any experience with TBI, just been reading a lot trying to learn. Hope to find parts soon. Patricks doesn't have the GMC 4 barrel manifold, so looks like I'll be building my own. As soon as my new dual Fenton exhaust gets here, will start pulling stuff apart. Jim | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | Don't think a tbi will work on it side to well. I bought a 91 astro van and took the tbi system off and put it on a 261 in my 55 cameo. used 4bb intake and tbi adapter. stock program in ecm. just put 305 ci. in place of 4.3 injectors. Port injection would be the way to go. The air throttle body could be on it,s side.. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Talk to BillUSN1 at Hamilton Fuel Injection on BinderPlanet.com. He knows his stuff and can probably recommend something. Lots of info on his sight for TBI. Good luck again. Jim | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | some fella told me about an engine management system, AEM. that you can use to control even sequential fuel injection, which I want to do on my next engine. And yes Talk to that fella @ binder planet, There is about 35 pages of thread from him on this subject here somewhere. All quite interesting
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | is anyone else having problems logging onto to binder planet? | | |
