| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | Happy Holidays and Merry Xmas to all Bolter,s. I have a request ,if I may. I have a 1951 stock G.M.C. 1/2 ton. I am putting new rubber on it and discovered that I have 3 stock 15" rim,s and 1 16". don,t work with 15" tires. I need a 15" stock rim-the one with inside clips. does anyone have a xmas gift for me Thanx Doug | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Hi Doug, I am looking for 16" rims. Is the one you have good? John | | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | I,m gonna have to have a good look at it. I need it now until I come across the proper replacement. its holding my truck up at the moment.. Doug | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fulltimeraye, let me have a look around. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I was thinking of swapping you a 15 for a 16. Whats on it for rubber? and what are you putting on yours for rubber?
| | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | Hello 54 john 3100 the rubber that is on the rim is junk. it sat from 1972 outside in the kootenays. is the 15 yu have a stock 51 style rim. I,m putting radial tubless tires on. thanks doug | | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | thanx 3b appreciate any help. I,m trying to keep it as original as possible. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I do have the clips for the hub caps. 6 clips are on the '54 and older and three clips on '55 and newer. 3B would have the proper ones also, if he has any. Knowing Bobb, he probably has piles of them. Any 16's Bobb? I don't believe you can go tubeless, I know I couldn't so all my 15 are radial with tubes. Is the 16 straight? I just brought 4 back from Creston and only one was true enough to use. Got them free so wasn't a killer. I'm willing to trade rims, if the 16 is true.
| | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | Good evening. that sounds like a deal alright. my cell # is 604 302 0991 give me a call and we can get together thanx Don | | | | | Joined: Dec 2013 Posts: 12 New Guy | | New Guy Joined: Dec 2013 Posts: 12 | Hello 54john3100. I havent heard from yu regards the 15" rim. my 16" looks good. Yu will have to look at it. give me a call so we can get together thanx Don @ 1 604 302 0991 cell | | |
