| | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 23 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 23 | I found the casting number on my 65 C-20 But it doesn't make sence I think the engine as be replaced. The casting #4437FT8 can anyone shed any light on this | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Are you sure that's a "casting" number...looks more like a stamped serial number to me. What engine do you think you have...is it a V8 or 6-cylinder??? Mike B  | | | | | Joined: Dec 2013 Posts: 23 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 23 | Thanks for your reply Mike I found the number right behind the distributor on the right side on the motor. It is a six cylinder and not a 292, The side covers are not big enough. So its either a 230 or 250. It as a electronic distributor, But that could be a add on.
Bob
