8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 8 New Guy | | New Guy Joined: Sep 2013 Posts: 8 | Hi, I finally doing something about my project and I am pumped. I know exactly what I want it to look and sound. My 66 pickup will soon be having an engine rebuild and Im considering having the 3 speed put on the floor. I'd like to have the engine juiced up and I figure the floor shifter would make for faster shifting. Would there be anybody with advice on this matter?
WolfeCustom
Built this Chevy on Rock'n'Roll
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | My last 3 trucks 55,56 and 57, back in the late 70's had the 3 speed with an after mkt shifter on the floor. I used the old tried and true original 3 speed transmission that came in the and they latterly caught hell. So yes it's done and will work.
O yeah I'm going to do it again with my 58 gmc. This time I'll give it a little more hp than the old 283s that I use to use. Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I wouldn't use the SM318 behind any thing much more than a 283 unless your very easy on the pedal. I replaced the sliding gear 2 or 3 times in a 64 Impala with a stock 300hp 327. I'd look for a latter all synchro 3spd. If you still have the stock rear axle find one with the overdrive.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | |
