4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#991033 12/06/2013 10:35 PM
Hi, I finally doing something about my project and I am pumped. I know exactly what I want it to look and sound. My 66 pickup will soon be having an engine rebuild and Im considering having the 3 speed put on the floor. I'd like to have the engine juiced up and I figure the floor shifter would make for faster shifting. Would there be anybody with advice on this matter?
WolfeCustom
Built this Chevy on Rock'n'Roll
My last 3 trucks 55,56 and 57, back in the late 70's had the 3 speed with an after mkt shifter on the floor. I used the old tried and true original 3 speed transmission that came in the and they latterly caught hell. So yes it's done and will work.
O yeah I'm going to do it again with my 58 gmc. This time I'll give it a little more hp than the old 283s that I use to use. Larry
58 gmc 100 with 350 sbc
I wouldn't use the SM318 behind any thing much more than a 283 unless your very easy on the pedal. I replaced the sliding gear 2 or 3 times in a 64 Impala with a stock 300hp 327. I'd look for a latter all synchro 3spd. If you still have the stock rear axle find one with the overdrive.
Larry
I don't own a vehicle that isn't old enough to drink.
If you are looking for performance, a close ratio 3 speed would be ideal.
http://www.smileysracing.com/shopping/?page=1&ic=1574
Check out this link. Good deal on shifter
http://www.tennesseespeedsport.com/MR-Gasket-7667A-Street-Shifter-3-Speed-Manual-Floor-Shifter.html
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
