2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Forgot to write something down again. Replaced the upper steering column bearing on my `59 Chevy 1/2 ton. Where does the tan wire from the bearing plug into? I don't see a stray wire hanging under the dash, so it figure it mush go to a switch or fuse block.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | The wire coming out of the column completes the ground at the horn relay. It does not go to the fuse block. The horn button is the switch. | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | So, all I need to do is ground that wire?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, it goes to the horn relay. When the button is pushed it grounds the relay. | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Found it. I had the other half of the plug tucked above the e-brake handle.
