| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99078 01/31/2007 2:36 AM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I cannot get my front parking lights to work. Replaced bulbs, checked wiring, made sure they were plugged in, (one headlight wasn't!) so I'm guessing it is the light switch? It is somewhat hard to pull the switch out. Haven't taken the switch off but have inspected from under the dash. Looks a little rusty. Any and all suggestions would be appreciated. Thanks, Wada [img] http://community.webshots.com/user/jjjwada[/img] | | |
#99079 01/31/2007 3:09 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Run jumper wire from + side of battery to to conection at inner fender well (assuming it an early modlel). If you would let us know what were working on, it would make our job easer. | | |
#99080 01/31/2007 3:10 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wada,
Aren't there some terminal strips on the inner fender wells, both sides/front that are a junction for headlights and parking lights. They would be easy to probe with your voltage tester to see if the power made it that far.
Stuart | | |
#99081 01/31/2007 3:54 AM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I'm sorry, I thought I put my information up. I have a 1951 Chevy 3604. I checked the terminals and cleaned them, working good. When I had a mechanic make my truck road safe he took a look by bypassing the headlight wire at the terminal and they came on. He was pretty sure it was the switch. Just wanted a few more opinions before I spend $40 on a USED one, know what I mean? | | |
#99082 01/31/2007 4:01 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wada, I haven't done the light switch drill, but I wonder if this could be a 'clean the contacts' kind of a deal...maybe a Coors & Crocus Cloth party! Stuart | | |
