8 members (Gdads51, frogfarmer, Wayne67vert, sron48, dt235sd, cmayna, Scott, 48jim1ton),
128
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Does anyone have a good idea of how prevent the parking light cover sheet metal edge from resting on the head light bucket. There is a gasket but it would have to stick out from under the cover to work and that will look bad. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the factory treatment might not look as bad as you imagine, certainly the gasket edge wouldn't look as bad as paint chips  you could always coat the bottom edges of the park housing with some liquid rubber, but if you don't do something to seal it up there, water will be getting in the headlight pots Bill | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | What about a small vacuum line or windshield washer hose, slice it down the length of it on one side. and slip that opening on the bottom edge of the housing all the way around it, that might just work. I might even try that myself when the time comes to put mine together.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Thank you both for the ideas. I am thinking I might try spacing the cover off the bucket with spacers over the two attachment screws. Just a few thousands. Iam guessing factory was just metal on paint. Had I thought about this before painting I think I would have added some tabs on the inside edge for a gasket to rest on. | | |
