2 members (papas52, UtahYork),
72
Mod | | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | I am trying to locate a pinion seal and axle seals/bearings for the 2 speed rear end in 1951 Chevrolet 6400. There are no listings and even Napa doesn't have a book anymore to find part numbers. Does anyone have a reference to these part numbers? I am trying to have this stuff on hand rather than tear it apart and try to find them after the fact. Thanks!
1953 Chevrolet Handyman Wagon 36k 1938 Buick 38k 1947 Hudson Commodore 18k
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Finding bearings and seals for old equipment is usually really easy if you stop thinking of them as a (in this case) Chevy part. Manufactures don't make their own bearings.
I just did a '48 2 speed rear.
Every roller, ball, needle etc. bearing has a number stamped into them. The same with lip seals.
Take the numbers off the bearings (and races if they are separate)and seals and go to your local bearing supplier. If they don't have them on the shelf they will get them in a few days.
You can also order on line if you want to wait for shipping.
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | I just found a hub seal for my COE by searching the number on the old one. Found it on Rock Auto for $3.00!! Bad part is it was a closeout. I bought all the bearings and races for my '59 GMc frt end from a industrial bearing supply house. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy bigblack'74, welcome, could you confirm which differential is in your truck? My truck salesmans data book shows the optional two speed rear axle as the Timken double reduction unit. It has been 62 years since this truck left the factory, and many changes could have been made since it left. To start with the Timken was a vacuum shift rear end, is that the case now? | | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | Thank you. Yes my '51 is a vacuum shift rear end.
| | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | The numbers stamped on the top of the 3rd member are as follows:
A7N430 6.13 8.10 M13 51 1.
The ratios are obviously 6.13 and 8.10. I assume 51 1 is January 1951. I do not know what the others mean. I cannot find any listings anywhere for a Timken-Detroit axle.
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy bigblack74, could you take a picture of the rear axle from under the forward side of it, and post it here. I would just like to confirm which rear end is there before I recommend which parts to order. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Another option if all else fails, Try not to tear them up too bad and take the old seals and bearings to a bearing & seal company, such as Motion Ind. If the old numbers are gone or not able to cross reference, they can mike them and come up with seals and bearings that will replace yours. When working on the old 2 cyl. John Deeres, I have had certain applications where the seal co. would recommend using 2 seals side by side. A double seal.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 |
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy bigblack'74, that is indeed a Timken double reduction two speed rear axle. The following list of parts are Timken unless otherwise noted, prices are USD at RockAuto unless otherwise noted pinion seal National p/n 475234N $6.74 rear wheel seals National 6358 $9.76 pinion bearings p/n 3875, one required, no parts found p/n 3820 one required $7.60 p/n 45920 one required, no parts found p/n 49585 one required, no parts found Intermediate shaft p/n 59162 one required, no parts found p/n 59200 one required, no parts found p/n 59412 one required, $25.99 Bull gear shaft bearings p/n 3994 two required $21.79 p/n 3920 two required $7.61 Wheel bearings, inner p/n KD12051Z $41.79 outer p/n KB 11786Y no parts found Hope that helps some.
| | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | That is fantastic. Thank you very very much. I can now get the parts before I tear into it. Do you have a listing for the Universal Joints?
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | That is the 2 speed I just rebuilt. Got all the bearings and seals at my local bearing shop, Capeway Bearing.
Any numbers they couldn't match over the phone I brought the parts with me and they matched them by dimension.
I haven't looked them up, but there MAY be a typo in the middle of the list
45920 and 49585 - possibly 45985? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy bigblack'74, I added the bull gear shaft bearings to the list this morning (I missed transferring them from my note pad to the confusilator screen). The "U" joints should be Napa p/n PUJ331 $14.85. I checked the number that Jim Sears was wondering if it may be a typo, and it comes out as I posted it in two different catalogs, I also found another bearing number for the intermediate shaft that I will place in the original post, so that all the info is in one post, hope that helps. | | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | I got the pinion seal/speedi-sleeve and bearing changed. The nut had to be torched off. It is a 1" x 20 tpi, if anyone needs to know. Thanks for all the info. I will next do the axle seals.
