3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
Hi guys,
Anybody have a drawing showing the dimensions on the input side of the transmission for the AD trucks?
Bellhousing to trans bolt pattern, input shaft length and diameter, pilot shaft length and diameter, bearing retainer length, etc I spent some time googling without satisfactory results. Thanks in advance.
regards,
Leon
3B Offline
Hy Leon, you have to tell us what year truck, the 1947 trucks used the older crashbox transmission, different mounting pattern and possibly different center hole.
Oh, I didn't realize. I thought all AD's 47.2 thru 55.1 were the same. I'm interested in the dimensions for the later ones, that have the same trans faces as 55-up. specifically 55.1
regards,
Leon
