| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | I'm in the process of trying to remove the seat riser of my 53 suburban in order to replace the floor. The front and sides are held in by spot welds (which I removed). How does the back of the seat riser connect? I'm guessing that it bolts to the cross support where the cab transitions to the wood.
I checked on tech tips but I did not find any info listed on this. Any help would be great.
Thanks Marc | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I just looked at my 1951 Chevrolet suburban seat riser.Looks like mine is spot welded along both sides and front.There is a cross brace behind the seat riser that runs the width of the cab.There are two spot welds on each side attaching to the cross brace.I see no other spot welds and no bolts on mine.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Thanks Tim. That is how mine looks and I have removed all of the spot welds that you mentioned. I cant figure out what holds the back of the seat risor. I was thinking that mabe it is held in by the carriage bolts that are running through the rear cross brace. ONly a guess thats why I'm asking for help.
Marc | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | There are no bolts showing on my cross brace. Must be some spot welds your not seeing.
| | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Thanks Tim. I will look it over again closer tomorrow.
Marc | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | part of the support of the rear goes under the trim or cap where it makes the transition to the rear section. I had to cut mine to remove it for repair and plan on welding it back in lace then install the seat riser. | | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Ol trucks..
Thanks, that makes sense becaue it sure felt like it was connected to that channel/Cap.
Marc | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Post some pictures of your seat riser removal.I'm sure others will benefit from it.
| | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Tim-
Will do once I figure it out. So far all I have to show for myself is a bunch of drilled out spot welds. The riser is still in place. I might get a chance tonight to work on it some more.
Marc | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | May be simpler to just cut it out from the bottom,, and go from there. Ive never seen an under seat section that needed that much work to where it needed the top cut off.
| | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | I figured it out. Cutting it out from the bottom would be just as difficult. Here is what I found out. There is a rear channel that spans the back of the cab. The back of the seat risor is welded to this channel. This is all covered by the wood for the back of the suburban. I used a Sawsall to cut the seat riser loose from the channel. You will notice that I also cut the top trim peice as well thinking that would help (which it did not). i will need to remake one anyway as this one had some bad rust through.
Here are some pics.
[URL=http://s79.photobucket.com/user/Youngrodder/media/51fa3f94-6a96-41c7-9685-c4e8b5fb92df_zpsfab6bf88.jpg.html][/url] If you look closly you can see where the metal seta flange goes underf the wood and is welded to the back channel.
[URL=http://s79.photobucket.com/user/Youngrodder/media/DSC09633_zps8ab2a7ec.jpg.html][/url]
[URL=http://s79.photobucket.com/user/Youngrodder/media/2321b833-9ecc-4cf1-b3b1-39cc386351f0_zpsb97b17ed.jpg.html][/url]
In the end I won. Now I can repair the edges of the seat riser and put new floors in. I will make my own floors as the kits that are out required work to weld up holes for stuff that I dont need for my application.
Marc
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks for the pictures.
I know of a guy that's going to make that lower section without the top of it. He ordered a die to make the beads with his bead roller.If you should need it made,let me know and well move this to the parts for sale section.
| | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Yes please, I would be interested.
Thanks Marc | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This guy is going to be making the lower seat riser frame.Feel free to contact him via phone or email. I don't think this will need to be moved,it's a parts supplier,I'm not selling. Brian Washburn phone: 816-806-9160 Email: [email protected]If you email him,put suburban seat riser in subject line. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
Thank you for your help. Will do.
Marc | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim has handled this correctly.
Person-to-person one-time transactions are not allowed.
Information about a source of parts/services available to all of us is, of course, useful information.
Thanks, Tim
