| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98960 01/23/2007 5:08 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | I'd like to install a tach in my '57 3600. Here's my situation: It's quite original looking inside with an original, working, AM radio. The only thing that is slightly unoriginal are the chrome knobs for all the stuff. AND I don't want to spend alot of $$$$. I simply want to know what kind of r's I'm turning. Any suggestions on a small, tasteful (and el cheapo) unit???? And where would y'all recommend mounting it so that it doesn't look odd and out of place. Thanks all. Yer the best!!! | | |
#98961 01/23/2007 5:58 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You have several choices.
Your FLAPS has any number of el-cheapo (and a couple that aren't) tachs that will work with your engine (just make sure that you buy one with the proper number of lobes), but they usually don't look very pretty.
The aftermarket gauge companies sell them, and they usually look pretty nice, but they're expensive.
You might try looking on ebay for an old sun gauge and sending unit. Those were used back in the day. For a 6 cylinder engine, you'd want an EB-7(a) transmitter, and for an 8 cylinder engine, you'd wan an EB-9(a). Any of the old-school black-faced gauges would look right at home in your cab. They used to make mounting cups that would clamp onto your steering column, so no cab modification is strictly necessary.
Some of the gauges go for a pretty penny, though. FYI. | | |
#98962 01/23/2007 1:20 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | orchidski,
I bought a 12v tach at Advance Auto for under $30 (on sale) and it is mounted to the steering column (6 cylnder 54 Chevy truck). It is between 3-4" in diameter and has plain numbering. AS I recall it had clear installation instructions with about three wires (one for alight) People who do not know what is original think the tach is original.
Brendan,
What does "proper number of lobes" mean? Obviously, a rare case of dumb luck got me through this installation.
Tim | | |
#98963 01/23/2007 3:22 PM | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I have a cheap one own my Model T F**d that I got at the FLAPS And it has a switch that can be set at 4,6, or 8 cylinder position. | | |
#98964 01/23/2007 3:27 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | "Proper number of lobes" might equate to selectable for number of cylinders, as 31,32,33 notes above.
Stuart | | |
#98965 01/23/2007 8:39 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Since you have an original working radio can we assume your system is still 6 volts? Make sure whatever you get is compatible with your 6 volt system. That may be a little hard to find at you FLAPS. | | |
#98966 01/24/2007 12:52 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by tclederman: What does "proper number of lobes" mean? Obviously, a rare case of dumb luck got me through this installation. Originally posted by atomarc: "Proper number of lobes" might equate to selectable for number of cylinders, as 31,32,33 notes above. Tim and Stuart: On my old Shop Tach/Dwell meter, there is a switch for you to pick whether your system has 4, 6, or 8 lobes. I assumed that this was a "standard" term... Goes to show what I get for assuming! :rolleyes: My guess is that lobes are what the wire hookups are called on the distributor. Of course, that's another assumption... Some tachs aren't adjustable... which is why I warned him to be careful. Originally posted by waldo53: Since you have an original working radio can we assume your system is still 6 volts? Make sure whatever you get is compatible with your 6 volt system. That may be a little hard to find at you FLAPS. In 1957, they were doing 12v electrical systems. IIRC, they started doing that in 1953 or 1954. | | |
#98967 01/24/2007 3:15 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brendan, I knew what you meant...I'm pretty sure the 'lobes' your meter is referring to would be lobes on the distributor cam, which would correspond to the number of cylinders the engine had. Stuart | | |
#98968 01/24/2007 4:07 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Any one selling a 6v tach for the AD 216? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#98969 01/24/2007 5:33 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Denny Graham: Any one selling a 6v tach for the AD 216? Denny Graham Sandwich, IL Ask me again in a few weeks... I may have one then. There is a shop selling them online. If you do a forum search for 6v tach, you should see the link to it. | | |
#98970 01/25/2007 5:53 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | My bad. I should have mentioned that it's 12 volt and that it came to me with a small block already installed. I'm a fearless asker of dum questions. Thanks again for all the info guys, Skip | | |
#98971 01/28/2007 9:37 PM | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | This may be a little late 4 u. Just installed tach from Pep Boys. A Sunpro. Its small and effecient.$29.99,has switch for 4,6,or 8 cyl. Mounting bracket for steering column. Needs large radiator hose clamp.
Works good!Ken | | |
