| | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Well, looks like I need to replace my gas tank. Any advice on where to buy, and exactly what to ask for?
| | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | How important is authenticity to you? How important is saving money? If you are in the Cleveland area, any Lake Erie boat shop can fabricate a tank identical to the size of the one to be replaced with the float hooked up to the gauge | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I had a radiator shop cut mine open (3 places) bead blast it. Weld it closed and then use the gas tank coating. About 200.00 as I recall. New tanks are about 400.00. The cuts are on the bottom. You have to remove the tank to tell. | | | | | Joined: Nov 2013 Posts: 10 New Guy | | New Guy Joined: Nov 2013 Posts: 10 | I just replaced the fuel tank in 46' pick up with a reproduction tank from American Classic Truck Parts. It needed a little adjustment of the flange corners and some slight grinding of the flange in places for a good fit but all in all it seems to be well made. I also had to drill an additional 1/2" hole in the bottom of the truck to accommodate a pipe port in the tank which would not allow the tank to lay flush on the floor. I'm pretty happy with it. About 375+ shipping. | | |
