| | | Forums66 Topics128,116 Posts1,056,637 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Looking into changing from the original single to the dual master cylinder but do not know what is involved. Is the back plumbing the same and I need new for the front?
How do I make this change?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | You'll need a mounting plate. Click here for example. I used a master from a '66 full sized Chev car (Not sure about the year but it was the first year GM used double master cylinders.)I ran the front line as original to the T block on the right side of the frame and plugged where the rear line used to go. I ran the rear line along the left side of the frame, across the rear end to the rear T block. This is for drum-drum, non-power, 1947 1/2 ton. I had to make some new brake lines.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you.
So. I assume the master cylinder is cheaper at a parts house and the new line parallels the existing line ( both T blocks are plugged in one direction) and new lines forward.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I do plan to stay drum-drum with no power assist.
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | You only need to plug the T block on the right rail (near the middle of the truck.) There is a T up front near the front wheel where the front splits to the left and right sides but that doesn't change. Cletis has a tech tip that provides a lot of info. My set up is different from his but the main ideas are the same.
