5 members (John L., baldeagle, Joe H, panic, 1 invisible), 92 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#98954 01/23/2007 5:01 AM
At some point I'm going to install LED brake/stop/tail lights. I'd like to put some sort of stop light bar or third stop light in the center somewhere on the back of my '57 3600 dump bed. I know this isn't an original look but I feel like I need to make the vehicle safe for today's driving. How does one incorporate a stop only light into a system that is wired for stop/turn?
#98955 01/23/2007 5:54 AM
orchidskip,
I think a simple method would be to tag a wire off the stoplight switch to the light bar. This would bypass the turn signal conglomeration and only allow the light bar to illuminate in a steady fashion when the brakes are applied.
I think there is also a little solid state device you can buy that attaches to a brake/turn wire and negates the blinking, giving you a steady light. This is how modern rigs with the third light work.
Stuart
#98956 01/23/2007 6:10 AM
Put a diode on each brake/turn light with the banded end opposite the light and run a wire from the diodes' banded ends to the third brake light.
#98957 01/23/2007 6:14 AM
orchidskip,
It's this little do-dad...
http://www.shop.com/op/~LOGIC_CIRCUIT_FOR_3RD_BRAKE_LIGHTS_-prod-17113925
Stuart
#98958 01/25/2007 5:57 AM
thanks guys!!!!
#98959 01/25/2007 2:57 PM
ODSS President
ODSS President
This third brake light (really an old license plate/stop/turn light) is eliptical. I took the cover off, taped up the socket and shot the inside w/ bright white paint. Shows up real well against my 'Farm Use' plate. Wired it direct to the brake light stop switch on the firewall.
I fabbed a metal bracket to hold the light in place off my wooden end boards.
~ Cosmo
1949 Chevy Half Ton
