0 members (), 63 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#988467 11/24/2013 6:23 PM
Am running my 49 with a 350. Does anyone know the temperate that this motor needs to run at.
Riding in the Passing Lane
Use a 180 degree therm.
1972 Chevy c10 Cheyenne Super
SEA DOG #988543 11/25/2013 12:43 AM
Ok thank u
It depends what thermostat you have, and on the rest of your cooling system.
There's not really a temperature it "needs to" run at, but as long as you keep it below 210 on the hottest summer day you're doing well. If it runs somewhere at 160-180 on the highway on a typical day that's perfect.
My 46 GMC on Photobucket
further thoughts to consider: the thermostat determines the minimum temp the system maintains, but a 350 is very unlikely to ever run lower than 180, probably more like 190-195, but that's with a 15 lb pressure cap, which is a bit much for the original rad even if it's in perfect condition ... you need to use at least a 7# cap, and it'd be a good idea to rig an overflow system as well
I run an 8-71blower on a 383ci in my '65 c-10. With the stock radiator, perma cool electric fan and 180 thermostat. Hottest my truck gets is 190. I also use purple ice by royal purple. It's an additive for antifreeze. The fan is 3000cfm and is on a temp relay with the thermostat. Cools after the engine is off to 180. You want to be around 175-190 I think. And if you're gonna cruise make sure it goes through a heat cycle. Get the condensation out of the oil pan and everything.
I know several guys with SBC powered hot rods that run well below 180.
What temp does yours run at 46gmcpu? Mine stays around 185 with an outside temp of 80-85.
The warmer the engine the more efficient it is. My preference is to have a engine at least 180. All new cars come with a 195 thermostat in them. There can be more factors besides the thermostat that affect the operating temperature of an engine.
I don't run a SBC in my truck so it's off-topic to talk about that here. I have SBC's in 2 other vehicles that both run at good temperatures, in the 180-200 range. I know several people that have trouble getting their SBC's above 150-160, it all depends on the cooling system setup and all.
SEA DOG #989198 11/27/2013 10:11 PM
Watch these thermostats. About half of the new ones are not any good. If the temp. does not seem right, try another one.
