7 members (klhansen, fonz8261, Shaffer's1950, Eileen, Uncles51, Rusty Heaps, 50Chevy3100), 87 guests, and 3 robots.
Topics128,079
Posts1,056,295
Members48,441
#988512 11/24/2013 10:59 PM
I am taking my 1952 6400 bed apart and came across some screws or bolts that bolt the side rails to the cross member together they have a round head with a odd shape in the center I do not know what this bit or driver is call. or where to get one
Thanks Jay
clutch head screws
Harbor Freight sells a drive-bit set that include 3 sizes.
Most of the reproduction parts companies sell clutch head bits/drivers.
A regular flat blade screwdriver will work, but make sure it is a tight fit in the head of the bolt/screw.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=949898
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=741689
Thanks off to Harbor freight
Gas Pumper
Gas Pumper
Anytime you want a modern solution that doesn't look modern and will last forever, get the button head screws/bolts from Totally Stainless. You can put the clutch head screw right beside the button head and you can barely tell the difference. Button heads are ALLEN head. They are sized very much the same as the old clutch head so its hard to see the diff.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
