1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98824 01/09/2007 8:03 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | What is the source of choice for the original "sideways" eyelet connectors? | | |
#98825 01/09/2007 3:53 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Are you referring to the electrical connectors that have the fork pointing at a 90 deg angle to the wire? If so those are called flag connectors and should be available at any electical jobber. If not you can get them here. They have a minimum order amount but I don't remember what it is.
#98826 01/09/2007 5:22 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | I don't know for sure what you are talking about,,I just use straight ones and bend to fit...doc | | |
#98827 01/10/2007 1:28 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Talking about the original wire ends for a 41 era truck. I was thinking they were eyelets, or circular over the posts, but maybe they are fork style. I need to pull the wiring out, but would like to get the parts to rebuild first. | | |
#98828 01/10/2007 1:47 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They would still be called flag connectors or terminals.
#98829 01/10/2007 3:38 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep just bought some for from YNZ's last month along with new Wade connectors, correct cloth wire, bullet connectors, etc. They are used on the wire from the coil to the distributor. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#98830 01/10/2007 5:07 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Can you give me a little more info on YNZ's, not familar with them. Also I apologize about the earlier lack of info. I alwasy giggle about posts like that and there I go doing it....LOL. Thanks | | |
#98831 01/10/2007 12:47 PM | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | |
#98832 01/10/2007 3:38 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | YNZ is the link in my first post. Give them a call. They are great folks to work with and know their stuff.
#98833 01/11/2007 12:42 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | | | |
#98834 01/13/2007 5:35 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I've also used Rhode Island Wiring Service and can highly recommend them. They have a nice catalog of all their wiring supplies, including the connectors you're looking for.
Bob | | |
#98835 01/15/2007 8:40 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Bob, do they have a website?...I'll compare. | | |
#98836 01/15/2007 1:14 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Try this Tom; http://www.riwire.com/ Denny Graham Sandwich, IL
#98837 01/16/2007 7:34 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Man, bad link for me...makes me want to just buy the harness! Thanks to everyone again...now I have to decide what I want to do. | | |
#98838 01/16/2007 9:30 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The Harness business is going the way the exaust systems went 20 years ago. You can't buy the parts as cheaply as having the muffler shop do the whole job. And you can run down the street and have lunch or a cup of coffee while their installing it. Denny Graham Sandwich, IL
#98839 01/20/2007 3:49 PM | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | both of those sites have nothing for the 55 2nd trucks. I know classic parts (chevy duty) has a pre fab harness, but will it work on a 1.5 ton? Are the marker lights below the head lights just parking lights, or are they turn signals too? And so would the lights on top of the fenders work with the marker lights in the front or? its a 56 4400 1.5 ton. It has the signal stat turn signal switch on the side of the column.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
#98840 01/20/2007 6:29 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Chris - the harness is the same for all the conventional cab TF trucks - the parking lights on all TF trucks are dual filament sockets [tail lights too], as there was an optional factory signal setup - your signal stat unit would work fine, you'd just have to adapt the wiring at the column to the plug, and if you want to keep the fender mount lights, split off the turn wire to them, which wouldn't be necessary with the OEM lights working - here\'s a pic of the harness - I'd suggest looking for an original turn switch setup, like in the parts wanted forum Bill | | |
#98841 01/21/2007 1:38 AM | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Thanks for the info Bill. So since my truck had the top fender lights, were they like factory turn signals? and would they have been tied into the front marker lights from the factory? And if the truck had thease factory turn signals, why does it have the signal stat untit instead of a factory unit? Is the signal stat unit aftermarket, a dealer option or? Maybe the signal stat was added after the factory setup went bad? If trucks could talk...
Chris
#98842 01/21/2007 3:19 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the sig stat is aftermarket, put on a truck that wasn't bought new w/ the turn sig option, and pretty common on these old rigs, added years later - because that part is non-OEM, the fender lights will be too, but there was 2 accessory options available, the one that used the parking light RPO987607 and others for flatbed/chassis only trucks that used fender top lights RPO987647 & RPO987643] you can see in those links the "switch housing" just below the steering wheel that will be there if it had the original signals, with a hole in the side for the lever and the lights on each side of the grill are the parking lights, which should have the dual element sockets even if it didn't come with the signal setup, marker lights are the ones on the cab roof Bill | | |
#98843 01/21/2007 11:44 AM | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Again, thanks for the info, that explains alot.
Chris
