| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Trying to install a Fulton model 800(I think) on my 53 3100. The front arm is flat not oval and does not seem to fit. It is the part that attaches to the lower part of the dog bone and the front of the shade half.Does anyone have a picture? I perfer a close up. Thanks in advance for your help
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's not the correct piece. That looks like one of the center supports. End View. Another End View. Center Supports.
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thank you Tiny, Here is a better picture of the part I have and can't seem to make work. I do have the center brackets however they are not what I am confused about.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Your part definitely looks home made to me. I don't see any reason you couldn't make a flat one work if you packed it. My Fulton is off my truck right now. If you want I could photocopy it and email it to you so you could get the size.
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks Peter, your help would be great.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They look home made to me as well. The original Fulton pieces are oval and pretty heavy construction.
