1 members (Peggy M),
169
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Hello, my 49 Chevy is sitting on a 79 el camino frame. I recently got new tires and rims and when I install them they are touching on the frame I then install spacers and they touch the outside of the fenders. I am going to replace the springs does anybody know from which truck they would fit. Thinking maybe s10 or so. Thank u guys in advance
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Try posting in the HiPO area. More folks there with experience with what you are doing. My best guess? You have tires that are too wide for your application. How thick was the adapter? If the adapter is less than 1 inch you have a very small window to fit into. If the adapter is over 1 inch you might. just might, get by with a 1/2 inch to clear the frame and not hit the fender. Springs? I have no idea what springs are available for the El Camino. I think they were upgraded car springs.
Steve H
| | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Ok I will try that thanks.. I have 1/4 inch spacers | | |
