| | | Forums66 Topics128,028 Posts1,055,413 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Just finished installing the repop headliner in my 53 Burb, what a PITA! I took my time, cutting, trimming, fitting over and over. Not perfect, some came up short in a couple of corners. Just want to point out that the replacement headliner required all the rear sections to be cut/trimmed and the front section at the windshield was precut. The precut section turns out to short all the way around! It came with the left sunvisor holes precut and they were off by one inch! Can't even cover them up. Consider this my rant! Thanks, Phil | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Who supplied it to you?
Is it possible they used the wrong pattern, That happened to me on a Studebaker Avanti.
Talk to the supplier and send them pictures. | | | | | Joined: May 2001 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 38 | Your not alone! Just put one in my suburban also too short in the front panel can't remember where I got it have to check my receipts I know it was a complete kit for 79.00 Frank | | |
