| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Hello, my 49 Chevy is sitting on a 79 el camino frame. I recently got new tires and rims and when I install them they are touching on the frame I then install spacers and they touch the outside of the fenders. I am going to replace the springs does anybody know from which truck they would fit. Thinking maybe s10 or so. Thank u guys in advance | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Sounds like your tires are too fat. How will different springs help you?
| | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | All I need is 3 inches higher. I guess that the bed of the 49 is heavier than the el camino one | | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Even if I were to install smaller tires I would have to raise it
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Maybe the back spacing of the wheels is off. Just a thought
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It sounds like something is the issue with your setup, and you're trying to remedy it by raising the back end instead of fixing the actual issue. If you give more info on your setup, wheels/tires, backspacing, tire size, etc., and maybe what was on there before and what you're trying to accomplish, we might be able to help you.
Do you have some pictures you can post? | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Seadog, If you bought new rims is it too late to return and get proper offset? Another solution is spacers come in many width sizes can you go to slimmer size? If can't return see below.
My chev is a 49 suburban but I am currently building a 46 Dodge on an 83 el camino frame. I bought some 15" rally style chev wheels at a swap meet and had to put in 1" spacers to keep tire from hitting frame due to the offset. Tires are "centered" width wiase in fender. I built a 1" square tube frame with enough height to make the floor level of bedsides sit on the "arch" of the rear kickup where the floor originally was. Then you can bolt/attach the bedsides to the tube frame at whatever height looks right to you. You will lose about 4-6" of depth in the bed doing this but my dodge will be a grocery getter and not a hauler. Hope this make sense as another way of solving your issues.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
