5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#987824 11/21/2013 9:03 PM
My truck has dual-purpose sockets from Carter which are wired for both park lamps & turn signals
Problem is sockets don't hold lamps in precise position required so after a couple hours of driving they jiggle out of position. I remove lens & re-align offending bulb which buys me an extra hour or two. Have tried stuffing socket sides w. paper to create a tighter fit, with limited success
Has anyone else experienced this? Suggestions?
Are the sockets plastic or metal? If metal, can you squeeze the socket to hold onto the bulb tighter? Can you put a small cardboard "sleeve" or tube around the bulb so that it's held tightly in the socket?
My 46 GMC on Photobucket
(soft) metal and have squeezed & shimmed with mixed results; problem is quality of the sockets that are supplied specifically for these trucks. Perhaps I shd get a pair of better quality sockets and jury-rig those to fit
Have never seen plastic lamp sockets for this application; do you have plastic holding the parking lamps on your '46 GMC?
I used universal sockets, I believe they're plastic. If the sockets on yours seem to be no good you may want to go to better sockets. Without seeing exactly what you're dealing with I can't comment further.
Mine's all-original including 6-jolts however sockets with offset pins should be same. Thx for your input, Shark
I met met Jim Carter this summer avnd he is a very reasonable guy. He wouldn't be happy to knowthat his part is faulty. I would give him a call.
1951 1 Ton Completed
Check some universal sockets from NAPA, Carquest or similar parts house. Stay away from plastic!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Why stay away from plastic? A lot of times they're better than the cheapo metal ones.
