| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | My truck has dual-purpose sockets from Carter which are wired for both park lamps & turn signals
Problem is sockets don't hold lamps in precise position required so after a couple hours of driving they jiggle out of position. I remove lens & re-align offending bulb which buys me an extra hour or two. Have tried stuffing socket sides w. paper to create a tighter fit, with limited success
Has anyone else experienced this? Suggestions? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Are the sockets plastic or metal? If metal, can you squeeze the socket to hold onto the bulb tighter? Can you put a small cardboard "sleeve" or tube around the bulb so that it's held tightly in the socket? | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | (soft) metal and have squeezed & shimmed with mixed results; problem is quality of the sockets that are supplied specifically for these trucks. Perhaps I shd get a pair of better quality sockets and jury-rig those to fit
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Have never seen plastic lamp sockets for this application; do you have plastic holding the parking lamps on your '46 GMC? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I used universal sockets, I believe they're plastic. If the sockets on yours seem to be no good you may want to go to better sockets. Without seeing exactly what you're dealing with I can't comment further. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Mine's all-original including 6-jolts however sockets with offset pins should be same. Thx for your input, Shark | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I met met Jim Carter this summer avnd he is a very reasonable guy. He wouldn't be happy to knowthat his part is faulty. I would give him a call. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Check some universal sockets from NAPA, Carquest or similar parts house. Stay away from plastic!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Check some universal sockets from NAPA, Carquest or similar parts house. Stay away from plastic! Why stay away from plastic? A lot of times they're better than the cheapo metal ones. | | |
