4 members (TooMany2count, lumbersawyer, Hotrod Lincoln, delky), 62 guests, and 3 robots.
Topics128,179
Posts1,057,157
Members48,465
Long story short...I pulled the engine after trying for a while to determine why it would not idle after taking tests and messing with the carbs/ignition. I got the engine apart and found two pistons have holes in them. #2 has some pin holes and a crack in the second piston groove. #4 has about a one inch hole in the second piston groove! No wonder my compression was so bloody low on #4.
So I am looking for new pistons and was wanting some recommendations. I'm leaning towards Egge Machine, but my old pistons were an awesome find and I was wanting something along those lines. My old pistons were domed for these engines. You just cant find that now days unless you go custom I looks like.
So, does any one know where I can get some more domed pistons? Or, who has a good vendor for reg. pistons? Egge looks to be around #216.xx for a set...Thanks for the help! I'm so [censored] they broke....
58' 3200 235 3-speed/OD
1 Offline
Being that they were domed pistons, that's likely the reason they are cracked. Broken ring lands is a sure sign of detonation. Dome pistons doesn't always mean better power and performance.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Think I would stay away from the domed pistons if youare building a daily driver. Go with a stock piston for that engine, make sure you have the correct heat range spark plug and that the ignition timing and point gap are correct.
well if your looking for new old stock try these guys I am assuming your talking about your 1958 235 engine
Lester J. Harris
2763 E. Valley Rd.
Minden, NV 89423-9097
775-267-2559
775-267-2241
Antique Auto Supply
1225 Colorado Ln.
Arlington, Texas 76015
817-275-2381
Fax 775-234-9858
Email: [email protected]
www.antiqueautosupply.com
or you bug these guys not sure what they have but maybe they can tell you who to go to.
Patrick’s Antique Cars & Trucks
P.O. Box 10648
Casa Grande, AZ 85130
(520) 836-1117
Fax: (520) 836-1104
www.patricksantiquecars.com
Langdon's Stove Engine Parts
47950 Robin St.
Utica, MI 48317-2461
586-739-9601
Fax: 586-739-9601
www.stoveboltengine.com
JJ Inlines
P O Box 1239
Sandy, Oregon 97309
503-762-5083
www.jjinlines.com
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Lester J. Harris
2763 E. Valley Rd.
775-267-2559
775-267-2241
Antique Auto Supply
1225 Colorado Ln.
817-275-2381
Fax 775-234-9858
P.O. Box 10648
(520) 836-1117
Fax: (520) 836-1104
47950 Robin St.
586-739-9601
Fax: 586-739-9601
JJ Inlines
P O Box 1239
Sandy, Oregon 97309
503-762-5083
www.jjinlines.com
56 Chevy 3100
If you have a local engine machine shop they should be able to get pistons easily enough. If not, Summit offers Seal Power pistons.
http://www.summitracing.com/search/...LET/Engine-Size/3-9L-235/Engine-Type/L6/
To my knowledge, domed pistons were never used in these engines as a factory piece, they are all flat top. I do know that domed pistons existed in the aftermarket, though. They pop up from time to time on Ebay.
Personally, I would suggest gong back to a stock type piston, my preference being TRW forged, just like the factory pistons were. Sealed Power pistons (with their rings) would also be a good choice. If you want a little extra compression, milling the head will bump it up a bit.
Bill Burmeister
H Online: Content
The "domed" pistons were used in the late 1930's-early 40's engines, weren't they? They've got a slight radius on top, not a huge lump like most folks associate with a racing piston. I've seen lots of NOS domed pistons on ebay auctions and they're always listed as early 216 applications.
Edit: There are several sets of 1937-1940 domed new old stock pistons on ebay now, in various oversizes. 1941-up pistons are flat tops.
You are correct Jerry, my '40 has the pistons with the dome.
Well my old pistons had the big lump and I believe they were for a 216 originally since I had to massage the domes to fit the 848 head.
I'm gonna go with some regular flat tops, probabl Egge if my machinist doesn't have a good source. If any one is building a race motor, I was able to find some domed pistons at ROSS pistons. They will do custom pistons for a number of different motors. The price listed for the 235 pistons was around $677.xx. Just for someone's future reference.
Have you checked Patricks. They list pistons for various engines. Was looking at a set of Venolias for the 270 when I get the time to work on it. Good luck. Jim
