3 members (Paul_WNC, thekid1950, TUTS 59), 23 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
Can anyone tell me if the 235 splash feed Harmonic ballancer will fit the pressure fed 235 engine as I've just fitted the early waterpump to my 1956 blueflame and
I think it may spin my pump to fast the diameter of my ballancer is 7 1/2 inches
Yes, low-pressure 216/235 and high pressure 235/261 harmonic balancers will fit on any 216/235/261 crankshafts.
thankyou TC for the information
Regards Chrislon
I'm told I need a 53 or 54 6cyl car harmonic balancer with the thin pulley so I don,t over speed my water pump can help me locate one
Regards Chris
The pulleys for the narrow fan belts (3/8") were used from 1953 onwards on 216/235/261 engines.
On truck engines from 1954 onwards, the diameter was 7.25".
It looks like a 3/8" groove 6 1/8" (smaller diameter) pulley was used on 1953 car & truck engines.
There were some 7.5" double groove pulleys for cars (1953 and later) - they would e close enough in diameter.
From 1937-52 the 216 harmonic balancer was a little over 6" in diameter.
The 1941-1952 235 harmonic balancer (5/8"groove) was 7.25" in diameter.
Is that sufficiently complicated and confusing?
Regards Chris
Place a Parts Wanted ad in the Swap Meet (state the groove width and diameter that you want).
If I'm not to late. I just purchased a used one from Langdon's Stovebolt Engine site. Great people and very knowledgable. reat price too.
Hope I'm not to late to post. I just purchased a harmonic balancer 3/8 belt from Tom Langdon at Langdon's Stovebolt Engine site. e is very knowledgeable and helpful. Prices are great too. Hope this helps.
I bought one from Tom yrs ago... good guy ..
Redryder pix
My Hotrod
