4 members (MarkT, WICruiser, Wally / Montana, MRMEROTH11), 113 guests, and 1 robot.
Topics128,068
Posts1,055,881
Members48,428
#985506 11/12/2013 12:15 AM
I have a question about the gas gauge in my 52 Chevy truck.I put a new wiring harness in the truck and a new ammeter gauge with a new 12v gas gauge.The gas gauge is wired according to the instructions with the new wiring harness but it doesn't work.I reversed the wires on it and nothing.I put it back to the original way and grounded the sending unit wire and the gauge still didn't react.What could be the problem.Thanks for any input on my problem.
nedde #985508 11/12/2013 12:19 AM
Could be many things
Most common are that the gauge is not Grounded properly.
check that the bezel is not pinching the Needle , the new gauges seem to have the needle set higher.
nedde #985517 11/12/2013 12:52 AM
If you are lucky you didn't ruin it by swapping wires. The first thing you need to do before troubleshooting electrical systems is educate yourself on the system. You can't just go swapping wires willy-nilly.
Did you check the sender for continuity?
DADS50 #985523 11/12/2013 1:04 AM
Thanks for the reply.I'll check it tomorrow.
Cletis #985525 11/12/2013 1:08 AM
I was told by a "auto electrician to swap the wires and the second thing is I followed the wiring instructions that were with the wiring harness.I appreciate the input.
nedde #985527 11/12/2013 1:12 AM
The original gauge came with a warning tag not to put power to the sender post
...pic...
nedde #985553 11/12/2013 2:05 AM
As Cletis posted (and DADS50 confirmed), if you reverse the leads and you put the hot input lead onto the sender post on the gauge, you most likely fry the gauge.
DADS50 #985868 11/13/2013 1:54 AM
thanks
tclederman #985869 11/13/2013 1:54 AM
thanks for the reply.
nedde #987590 11/21/2013 12:09 AM
Where can I buy a good 12v gas gauge? Are all the repros the same? I've got one I'm getting ready to send back. It doesn't have stops so the needle falls down past empty or full, completely out of view when the power is off. As DADS50 said above, the needle is set higher, so the glass bumps when I try to put the cluster back together.
MarcusT53 #987601 11/21/2013 1:11 AM
What make, year, and model?
nedde #987674 11/21/2013 4:26 AM
Its a 53 3100 Chevy. AKA 'my baby'.
MarcusT53 #1099384 04/25/2015 7:21 PM
My new gauge is the same way but as long as I keep gas in it the needle stays in view.I bought my newest gauge from CPI Truck in Roanoak,Alabama.There website is www.cpitruck.com.
nedde #1099386 04/25/2015 7:28 PM
Most of the reproduction parts vendors should sell a 1953 12v gauge ("Links" link at top of this page).
Most likely they are the same.
Choose based on for total price (shipping/taxes).
