| | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Need rear wheel opening measurements on a 1939-46 Chevy panel truck or suburban rear fender also if anyone has pictures of one off the truck. Thanks!!!! 1-262-392-2989 or [email protected]Marv.
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Marv -- are you asking about rear fender configuration? If otherwise, I don't understand your question | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello Marvin!
A friend of mine is restoring a 46 1-ton Canopy Express and I'm going over there Saturday morning. If you let me know what measurements you need, I'll try and get them for you.
Randy B. Slinger, WI | | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | I sent out 3 pictures of a right rear fender to your email addrerss as shown above. I hope that will help you out. If needed I can get some measurement of that fender. Of If you need more pictures,let me know | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | ranchojuan sent me some pictures and is going to give me the measurements also. Thanks!!!!!! to all for your replies. Randy from what I know the 1 ton panel rear fenders are not the same as the half tons. Thanks!!
Marv.
