8 members (J Lucas, klhansen, Tronman, electors, 78buckshot, cmayna, JW51, 1 invisible),
73
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 3 New Guy | | New Guy Joined: Jul 2012 Posts: 3 | I want to put a tilt wheel in my '53 1/2 ton. I could go with one of the aftermarket columns, but would prefer a Chevy column with ignition switch and wheel lock. Has anyone found anything that swaps in easily? | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | nothing is easy. you can use a mid 80's gm column . you will have to cut the shaft comming out of the steering box and put in a u joint. and fab a column mount at the dash | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | And don't forget the shifter. It will need to be addressed as well.
regards, Leon | | |
