| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | I finally got my 51 home to discover that the "all original" is actually a 46 chassis (8PK110526) with 52 doors and a GM stamp on the motor is a number that doesn't seem to match anything. block stamp 3336704 GM. What the heck did this come out of??
1952 Chevy 3100 1953 chevy 3100 Hot Rod 1946 Chevy Pickup
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | How did you arrive at the idea it is a '46 chassis?
3336704 is the format of a block casting number, not a stamping, However I can find no reference to that number.
Where did you find the 8PK110526? | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | when you look up that number on the ID plate, it comes up as a 1946. although it could be a 46 cab?
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How about posting some pictures of your truck, then we can help identify it for you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jim911, The 1946 cab is distinctly different from the 1951 cab. Which style cab do you have? 8PK110526 could be a 1946 Vehicle Serial Number. It could be a VSN plate from another truck (taken/used for titling/registration purposes). 8 = Atlanta, GA assembly plant PK = 1946 4400 truck I = August 110526 = 110526 - 1000 = 109526th truck out of that plant that model year You say it is a 46 chassis and 52 doors? How did you ID the chassis? Where did you find a chassis ID? What is the code on the motor (pressed into the block just in the ledge to the rear of where the distributor goes into the block). Motors are often replaced. | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | I think I was mislead when I ran the number as a "VIN". it jumped right to 46 just like you have for the PK. this is where the confusion started. it is definitely a 47-55 body style. it was sold as a 51 but has the push button door handles that started in 52. I'll have to look tonight for the number behind the distributor. the block number I found was all the way to the front on the distributor side.
| | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | the best I can tell without degreasing the block, the number is KBA6089
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I presume it's a Chevy, vs. a GMC? Sometimes VIN's are stamped in large letters, outside of R frame rail, near front spring shackle.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | KBA = 1952 3100 216 engine and standard clutch GM did not stamp an ID on the frame on 47-55 Chevrolet trucks. Some states may have required a stamping be placed on the frame (in those years). | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 |
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've read rumors that some states titled vehicles by the year sold. That could be why it's titled as a '51. | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | It could be Cletis. After further investigation and all you guys help, we have determined beyond a shadow of a doubt, it's definitely a 52 with matching engine and chassis. Whew! I don't think I'm going to try and change anything with the DMV though. That would be another whole set of issues! Thanks guys. I am the idiot and you are the genius!
