3 members (klhansen, kurbside bolter, wilbur53), 172 guests, and 2 robots.
Topics128,266
Posts1,058,369
Members48,485
#987232 11/19/2013 2:11 PM
I found a bent push rod on #1 intake of my 216. After doing a search here the problem was old gas that allowed the engine to start and run but varnish seized the valve after sitting up for a week. I did the 50/50 acetone and Marvel Mystery Oil on the valve and lightly tapped the valve to break it loose. It was still SLOW to return to the top when I turned the engine over by hand so I put a halogen work light on the valve to warm it up. That did the trick. After a new push rod & a few more revolutions to assure it was returning to position I got the engine started with fresh gas and now back on the road again. Hope this helps someone else.
That has been preached on this site for years. Sorry to hear you didn't read it here first and had to suffer through it.
