| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | Hello, I searched here, Jim Carter, Chevs of the 40's, and Dixie Truck Works. I can't find where to get new brake shoes for my 41 Chevy 1.5 ton. I would be willing to send them off to have them re-lined. Anyone got a company name for me? And, any articles, (with pics  ), to help me with this project would be great. The manual is not that descriptive. Thanx for your help in advance. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | You will need to find the little obscure "hole in the wall" establishment located in the low rent area near you that still relines brake shoes. You may find him in the phone book under brake and clutch, or start by asking your real auto parts guys.
As long as your brake cores are good it should not be a problem. The guy I found locally had to order the friction material, but it was not too expensive.
The aftermarket companies seem to ignore the bigbolts. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Any commercial truck shop should be able to point you to someplace that can reline your shoes. | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | 1fletch, if you can't find a shop in your area, I sent mine to: Automotive Manufactures, Inc. in Richmond, VA. They relined 4 shoes for the bus cheaper than I could have purchased them for, if I could have found them.(and I couldn't).
I also needed shoe return springs for the rear and couldn't find them anywhere. Found a shop in Xenia, OH, Timac Spring Manufacturing, Inc. They advertised "no job to small". Couldn't believe they made 12 return springs exactly to spec. for such a low price.
Good luck with your truck. Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Clutch exchange in Denver, does that work.
| | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | Thanx for all your responses. I live in a small county, I couldn't find anyone who could help me. So Victor, I'm gonna run with your idea. I'm not in a big hurry so sending them off will work just fine. Thanx again guys for stopping by and giving me a leg up. | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I had a very pleasent experience with them. Great service! I told them I had to clean them up first, because they were all coated with grease and gunk. He said, "don't worry about that, just put them in a plastic bag, box 'em up and send 'em...we'll take care of them."
And they did! Came back quickly and brand new. I'll be interested in your experience with them before making future recommendations.
Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | fletch, Thanks, for asking.
Victor, Thanks for the lead/recommendation.
I bet they would also reline the brake "shoes" on the drive-shaft brake?
With Priority Mail fixed-rate-box shipping and no out-of-state sales tax, sending shoes off is not a bad deal.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | These guys have been around a lot longer than I have, still don't have a web site, but they do the work that old brake service companies used to do. http://www.yellowpages.com/listings/3492896/gallery | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | The reason you didn't see them at Jim Carters is because they take your cores and have them relined. You have to call and speak with Jimmy. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Pueblo brake and clutch in pueblo Colorado relined mine for 60$ | | |
