9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
The bottoms of my sliding window frames on my '60 Burb are rusted through. My original plan was to replace the back sliders on each side with a solid glass pane, then taking those back frames, cutting out the top of the frame which isn't rusted, and after a little work welding it on as a new bottom on the middle sliders. I went to the Good Guys swap meet yesterday and one of the vendors there said the slider window frames for the '60 are the same size all the way up to 1966? I've just been looking for frames from '60s and '61s. Does anyone know if the frames are the same from '60 through '66? If so, I've got 5 more years worth of Burbs to look at to try to find 2 good non- rusted ones. All help greatly appreciated.
Pretty sure they are all the same, I got some nice used ones from Aridzona.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks Shop Shark.
Do you remember where in Arizona? I've gone to salvage yards in Phoenix but all I've seen have the same rusted out issue. Any and all help appreciated.
'60-'66 Chevy/GMC Suburban Carryall sliders are the same. As you know, driver-side front, driver-side rear, passenger-side front & passenger-side rear, sliding window frames are all position-specific and are not interchangeable.
Thanks Tony. I apologize for the delay in reply and appreciate the info.
Gregg
