1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98680 12/30/2006 6:16 PM | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Did the 60 Apache 10 models have factory turn signals? Mine has turn signals in the steering column,but they don't self cancel unless I'm missing the cam part. The column is chromed so I'm sure that's not original unless it was chromed by a PO. The turn signals are wired also to the 2 orange lights on the dash that say tandem and overdrive. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | |
#98681 12/30/2006 6:31 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Yes they did.Even a chrome column can have GM guts.Sounds like the cancel springs are bad.Pull the steering wheel and check the springs R&L and the plastic cancel cam.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#98682 12/30/2006 10:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original had the application parts under the stg. wheel & a electrical switch down on the column with a cable going to it. It should cancel. Check for broken or missing parts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98683 12/30/2006 11:06 PM | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks for the replies. I'll pull the wheel and take a look at it. I put a new steering wheel on and don't remember seeing a canceling cam, but I'll look again. Happy New Year, Joe
#98684 12/31/2006 3:14 PM | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Another question,my instrument cluster only has one green light on the right side for the turn signals. So I'm assuming this is for both the right and left turn signals? Joe
#98685 12/31/2006 3:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes. I,m not shure how they wired that cause they still use a 2 prong flasher. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98686 01/01/2007 4:12 AM | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Sounds like you have a gauge cluster from a big truck such as a c60.
You mention "tandem and overdrive" as being used for signal indicators or wired to "the two orange lights" also you mention one green indicator for signal lights.
To the best of my knowledge this is more the big bolt configuration.
But that is neither here nor there as far as cancelling is concerned. If you have guts behind the steering wheel the fixes have been noted in other replies and I agree that more than likely you will find a malfunctioning cancelling cam.
If the guts of your system are located in a housing that appears to be part of the signal lever, normally attached to the steering column with a band,take it apart and check the springs,clean and oil all parts and reassemble.
The single green light indicator functions through a different configuration of the wiring harness and uses the same signal stat in the fuse panel.
Hope this helps,Hobert
"The Lord is my shepherd"
#98687 01/01/2007 2:06 PM | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks again for the replies.I think you're right about the cluster being from a larger truck. I looked again and the orange indicator lights say TAND'M LOCK and OVERSPEED, where the green turn signal indicators should be I'm guessing. Maybe I'll change those lenses to green. Now if I can find a green lens that would be great, I only need one. I ordered a cancelling cam for the turn signals, I don't remember seeing one the last time I replaced the steering wheel. Joe
#98688 01/02/2007 12:34 AM | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Hey Joe,I have several of those gauge clusters and you are more than welcome to a green lense.
If you would like me to send you one just PM me your address and I will send it to you free of charge of course.
Hobert
