1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | What should I use to seal the floor board and toe board on my 42? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Take your pick: http://www.tcpglobal.com/3m/3m600-3.aspxBody shop supplies and most of your FLAPS stock it also. Denny G
Denny G Sandwich, IL
| | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Gerry,
The floor board should not be caulked or sealed as it needs to be removed periodically for access to your battery and master cylinder. Also, the toe board was not originally sealed with any material. A floor mat serves as a sealant for water and air infiltration.
Paul
Paul | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Mine also serves as a drain for the leaky windshield  Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Fo got about those wooden floor boards Paul, to focused on the AD versions. Your right, you don't want to seal them up. Might look into using some closed cell weather-stripping on the bottom sides though.
Denny Graham Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | 42 would have metal floor boards. Some have rusted out ones have been replaced with wood. | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I have a 41 AK and mine are all metal. I don't think they have ever been replaced. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Wood toe or floor boards on 1941-46 models (perhaps 1939-40 as well?) would have been an aftermarket "bubbafication". The original floor board is rather flimsy in comparison to other panels on these trucks, and they did not seem to weather very well.
I bought a nice shiny $95 reproduction floor for mine off of eBay. In retrospect, the repro took more time to fix than fabricating a new one would have taken. Fool me once... | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I too bought one of those eBay repop floor boards, about 18 months ago. I've been delayed in trying to check the fit. What problem(s) did you experience? Thanks
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | 46Sparky,
The reproduction floor board was the correct dimension and fit in the cab fine. The problems were that the master cylinder access hole was in the wrong location (approximately 1.5 inches off but still okay "as is"), the battery access slot was 1.5 inches too far towards the front, and the floor perimeter brake bends were very inconsistent in their depth from one side to the other. My original floor had consistent channel bend depths of 0.50 inches on the 3 sides that should be bent, whereas the reproduction floor varied from 0.50 to 0.75 inches. Nothing fatal, but just needed more work than I thought it should given the price. As I stated before, if I were to do it again, I would just fabricate my own. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I too bought a repop. I had to rework the corners a bit. I just put down a fiber electrical tape on the mating surfaces. I don't think if all is sealed as it should be there is not much water to get in. Everything is primed and top coated. It will be interesting to see if the windshield leaks. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Thanks guys. Looks like another opportunity to spend more quality time on the project.  | | |
