| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | OK, converted my 54 3100 to 12V. Had the generator converted. Install a 12V regulator, 12V coil, ballast resistor. Polarized at the regulator. Changed all Bulbs and added voltage reducer on fuel gauge. Started did not show discharge, but it was ok. Ran it for awhile, gauge pegged to discharge, generator was smoking. Looked like battery leaked fluid. What happen? What did I mess up?
awk
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Have you checked the current and voltage output of the new setup? Until you actually know what it's doing all you're doing is guessing.
| | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Had the generator and regulator checked. The new regulator was bad. The auto electric place replaced it. So should be good to go. Will install tonight.
awk | | |
