6 members (54farmtruck, Bill Hanlon, dt235sd, Bisbee, Otto Skorzeny, klhansen), 102 guests, and 3 robots.
Topics128,148
Posts1,056,811
Members48,454
After removing the cluster I found that the rivet which holds the fuel gauge to the backing plate has broken. One of the wires is also broken. What would be the best fix? Is this common?
I am considering soldering the wire and the rivet back on the plate.
Thanks!
Riding in the Passing Lane
Replaceing the gauge would be the best fix but if you have ideas to fix it it,s worth a try.
1972 Chevy c10 Cheyenne Super
