| | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | prob doing backwards but have a recent rebuilt 49 235. want to put in a 58 apache.the starter/flywheel has been changed to 12v the front mount has 2 holes bottom and 2 at about 45 degrees.the 2 at 45 degees used for cars. cant find a picture or diagram of how bolted on cars. i can find new rubber mounts but not bolts ect for cars.or even a diagram photo would this work instead of the hard to find complete assemble that bolts under front plate. i know i will have to do some mods ?? thanks
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The best I can do at this time is this picture(frame 14) that shows the pass mounts on the timing plate. You will need to adapt to the crossmember.
See the USA in your vintage Chevrolet! My Blog | | |
