0 members (), 81 guests, and 5 robots.
Topics128,179
Posts1,057,160
Members48,465
rwb
Offline
prob doing backwards but have a recent rebuilt 49 235.
want to put in a 58 apache.the starter/flywheel has been changed to 12v
the front mount has 2 holes bottom and 2 at about 45 degrees.the 2 at 45 degees used for cars.
cant find a picture or diagram of how bolted on cars.
i can find new rubber mounts but not bolts ect for cars.or even a diagram photo
would this work instead of the hard to find complete assemble that bolts under front plate. i know i will
have to do some mods ?? thanks
The best I can do at this time is this picture(frame 14) that shows the pass mounts on the timing plate. You will need to adapt to the crossmember.
My Blog
I have several factory filmstrips with a few pictures you can look through, here is one.
http://www.flickr.com/photos/advance-design_parts_co/8603092624/in/set-72157633120087261
