4 members (Gdads51, GMCJammer51, 2 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | What shocks should I look for at the Auto Parts Store if Im putting the mono leaf springs on, 4.5" drop in the rear and 3" drop in the front?
I would prefer not to have to hunt and peck for a pair of shocks when I get there. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I'm just using the AutoZone oem replacements and I'm about -6" in front and a little more in the rear. Never had a set go out on me on any other lowered car. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | So I dont need to get a smaller shock then? | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | If you don't account for the drop you risk bursting the shock housing at a full compression. The shaft will be too long. It could bend, burst etc... I would hunt. These are gas shocks correct?
| | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | On my 1954 GMC with monos all round I used Monroe 5751 front and Monroe 5803 rear. Mid travel for these is about my ride height.
1954 GMC 9314 - 261 t5
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Check out Post #51 here. My truck is a '65, but the link has some good data on measuring and then looking up shocks onlince. Hope that helps.  | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, your should have shocks that are at mid-stroke at ride height. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I don't worry about it. If one ever starts leaking or goes out (or I start bottoming out shocks) I'll consider spending the extra on shorter stroke units.
It's not like it's catastrophic if one goes. Heck, you probably won't even notice it's blown until you see the fluid on the shaft, case or other adjoining parts. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Good point. I drove one a single shock In the rear for about a year. Just had a lot of roll. Shocks are what? $40 a piece?
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | lol. Even with good shocks these trucks have a lot of roll. I wanna say the basic ones are like $40-50 a pair at AutoZone.
[EDIT] Yep. Just checked. $19.99 each. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I lowered my 65 with a kit from early classic. Came with new 2.5" drop spindles for disc. 1.5" spring and appropriate shocks for the front. Rear was a 6" drop coil and a set of appropriate shocks and a panhard bar. I wanna say it was like $750 for everything. It was 14 years ago so don't quote me.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | canuck49 that's exactly what I was looking for, a part #. I ordered it at Advanced, will get it in 5 hrs. Here's to hoping.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | The rear shocks worked perfectly. I have to wait on the fronts till after I put the new leaf springs on it. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Just a heads up y'all. The Monroe 5803 in the rear worked before I put the c notch kit on. I had to use a Monroe 5818 instead.
I am installing the front leaf springs today. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Front end is done. I was expecting more of a drop but it's ok, I'm going to do the dropped front axle in a couple months | | |
