7 members (wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag, Southerntruck, 60steve), 113 guests, and 3 robots.
Topics128,212
Posts1,057,468
Members48,471
Hello,
Does anyone know what the reason for this is?
Click on link below to view Photo:
Toque Tube welded on Tab
I have seen these Tabs on a lot of 1947-54 Chevy 1/2 Ton Torque Tubes.
I always wondered what they were for?
Leo Offline
Moderator
Moderator
Mine has that too, just assumed it was for balance.
On some years the E' brake return spring attaches there.
My Blog
As Pre68Dave said. Its for the E-brake return spring.
ditto, e-brake spring
Since the torque tube doesn't rotate, the only balance this tab would provide would be in a wicked Richard Petty multiple rollover he had late in his career. You need to see a video of it if you haven't already.
What models had a spring hooked to that tab? I had two theories, First was to protect the lip of the torque tube as it was separated from the transmission as it's tendency is to drop down and in a hurry, and Second (and I felt was my better theory), tied in with the mystery key shaped hole un the cab floor under the seat. I envisioned some sort of lock to hold the driveshaft up when there was no engine or transmission to keep the truck frame mobile. (whether for service or actually in the assembly line process)
Before I saw all the e brake spring answers, I was thinking it was something that would have made assembly easier at the factory.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
I actually think it was both.
My Blog
I thought the welded on tab might have, somehow held the torque tube,
to help form the taper in the tube, from the larger diameter to the smaller diameter.
